音樂大廳 Forum Index 音樂大廳
Ruleless
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
期待新的隨身耳擴......
Goto page 1, 2, 3, 4  Next
Post new topic   Reply to topic    音樂大廳 Forum Index -> 技術交流廳
View previous topic :: View next topic
Author Message
coffin
Topic Manager
PostPosted: Fri Jun 29, 2007 8:59 pm    Post subject: 期待新的隨身耳擴...... Reply with quote
期待中∼∼AMB大大的Mini3 v2: A portable headphone amplifier
Back to top
View user's profile Send private message Visit poster's website
steel
館主成員
PostPosted: Fri Jun 29, 2007 10:08 pm    Post subject: Reply with quote
這一版看起來應該可以成功
期待他的上市... Good Plan
_________________
我的部落格---DIY的音響世界---
Back to top
View user's profile Send private message Send e-mail MSN Messenger
ucc
PostPosted: Fri Jun 29, 2007 10:44 pm    Post subject: Reply with quote
Very Happy 那OP輸出電流蠻大的說 Very Happy
Back to top
狂人
PostPosted: Tue Jul 10, 2007 12:39 pm    Post subject: Reply with quote
amb wrote:
狂人 wrote:
I'm wondering if MELF type resistors (looking like through-hole resistor but without the legs) are usable on Mini³ boards? Since there are some quite high quality resistors available in MELF forms (Like Vishay Dralorics MMU0102).
If you're referring to something like these MELF resistors, there is no convenient way to solder them onto the PCB pads.
The board was laid out for 0204 through-hole (leaded) resistors with 5mm pitch. The recommended resistors have a body length of 3.5mm or 3.2mm.
Anyway, this is off-topic in the β22 thread. Further discussions about Mini³ should go to the following thread:
http://bbs.audiohall.net/viewtopic.php?t=4720
continuing from another thread.
I'm wondering if it is possible for the pad on Mini3 to contact the MELF 0204 resistors? Or maybe lengthening some of the pad slightly so that MELF and 0204 through hole can both be used, depending on user preference.
Just my hope anyways Razz Been really eager to try those resistors out Razz
Back to top
amb
PostPosted: Tue Jul 10, 2007 3:44 pm    Post subject: Reply with quote
The MELF 0204 resistors are 3.6mm long with its solderable end-caps starting at 1.8mm, so it's too short to reach the 1.27mm (diameter) pads spaced 5mm apart. Also, the cylindrical shape of the MELF resistors makes them difficult to position for soldering -- they would tend to roll around.
At any rate, production Mini³ boards are already being fabricated, so it's too late to change.
A goal of this amp is to make it as compact as possible while keeping it easy to build, so aside from the opamps all other parts are through-hole. The design is tightly-integrated with a specific case, volume pot, jacks, opamps and other internal parts. The specified 1% metal film leaded 0204 resistors are excellent for this application and I don't feel that there is any tangible benefit with other resistor types.
In fact, I would strongly discourage builders from trying to "improve" the amp by substituting other parts, especially the opamps, or any other parts that might cause fitment issues. This is not an amp where you could get away from using axial-lead capacitors in positions designed for radial, or mounting oversized resistors vertically "tombstone style". The extra lead inductance from doing so could cause stability problems because the opamps are very high-speed, wideband devices which are very sensitive to layout issues.
Back to top
狂人
PostPosted: Tue Jul 10, 2007 5:51 pm    Post subject: Reply with quote
Understood, personally, I do not like to mount resistor tomb stone style, nor do I like to use axiel in places where they do not belong. So that would not really be a problem for me.
OP-amps, well seeing your message gave me the feeling that it was a PITA to pick the proper amp and tune it properly, so I won't change that either.
I'm just REALLY interested in sticking that MELF resistors on... Ah well, there's always another amp that I can stick that on. Razz
Back to top
狂人
PostPosted: Tue Jul 10, 2007 10:40 pm    Post subject: Reply with quote
Just remembered that Vishay S102 resistors are also sized to fit the spot on Mini3... I suppose those should work should someone got a fair bit of cash to burn, right?
Back to top
amb
PostPosted: Wed Jul 11, 2007 7:15 am    Post subject: Reply with quote
Yes, they would fit if you form the leads to 5mm pitch. Due to the height of these resistors things could get awfully crowded on the board, next to the L1L and L1R ferrite beads. I don't see why this circuit would need that kind of tight tolerance and temperature stability, though.
Back to top
amb
PostPosted: Wed Jul 11, 2007 3:10 pm    Post subject: Reply with quote
For your enjoyment... There are more pictures here.
Back to top
狂人
PostPosted: Wed Jul 11, 2007 5:24 pm    Post subject: Reply with quote
AMB, honestly speaking, you really should carry those custom panels. No Mini3 should be without it Razz
Back to top
amb
PostPosted: Wed Jul 11, 2007 5:37 pm    Post subject: Reply with quote
Yes, they are excellent and make the amp rival commercial products in look-and-feel. However, these panels are expensive for me to stock, so I am running a group-buy on headwize right now.
Back to top
coffin
Topic Manager
PostPosted: Wed Jul 11, 2007 11:49 pm    Post subject: Reply with quote
還有還有∼∼
Back to top
amb
PostPosted: Fri Jul 27, 2007 1:19 am    Post subject: Reply with quote
The new Mini³ website is now live. Some sections are still under construction, so please pardon the mess.
Enjoy,
Good Plan
Back to top
coffin
Topic Manager
PostPosted: Thu Aug 23, 2007 1:26 pm    Post subject: Reply with quote
恐怖的面板陣列 o19 o19
裝可愛~
Back to top
ljvalue
PostPosted: Thu Aug 23, 2007 2:06 pm    Post subject: Reply with quote
coffin大開的團嗎?
那有沒有機殼的?
Back to top
Display posts from previous:
Post new topic   Reply to topic    音樂大廳 Forum Index -> 技術交流廳 All times are GMT + 8 Hours
Page 1 of 4
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
